March 30, 2020
“It’s amazing that we are able to develop an application within 1 day, which ensures that everybody uses the same analyses and models. This saves time and reduces the chance of errors.” - Tjeerd Hermsen, BIM manager at Sweco
At VIKTOR a lot of experience has been gathered over the years regarding the analyses of (batch) calculations in a custom online tool. The input is often desired to be variable, which means a lot of different scenarios (models) can be evaluated with a lot of computing power.
VIKTOR offers an easy solution. Models can be uploaded to the VIKTOR interface and the variable input can be specified. All it then takes is to press the run button. The models are then generated and evaluated on the server. While this happens, your laptop stays available for the next Zoom meeting, and a notification is given when the results are ready. Go ahead and grab a cup of coffee.
An example integration could be analysing a D-Foundations model with a large amount of cone penetration test (CPT) data. In no time, hundreds of bearing capacity calculations for various locations are performed. Or perhaps you would like to analyse a structural model in SCIA Engineer, with a variation in geometry / loads / stiffnesses, or assess the reinforcement configuration in IDEA StatiCa. Implementing these functionalities can be done in VIKTOR with very little effort.
Integrate your current software with our standard integrations, or we can assist to set this up for you.
“With the integration between IDEA StatiCa and the VIKTOR plaform, our customers can perform a lot more calculations in less time.” - Jo Gijbels, owner of Whitebox Engineering Software
September 29, 2026
September 22, 2026
