August 21, 2025
What's new in VIKTOR (August 2025)
Another month means another round of updates to make your VIKTOR experience better, faster, and easier. This August, we’re rolling out several updates: OAuth 2.0 support for more secure integrations, automatic test apps to make testing and sharing easier, dashboard entities without lock for smoother collaboration, improvements to the App Builder, and faster app publishing so you can iterate at lightning speed.
OAuth 2.0 support in VIKTOR
Integrating third-party services into your VIKTOR apps is now even easier and more secure! With OAuth 2.0, you can:
  • Create connections to any cloud services you use in a secure way
  • Use the pre-populated integrations we have created with Databricks and Autodesk Construction Cloud (ACC)
  • Enable those integrations on apps so users can bring in the data they have access to in other third-party services
Read the documentation to learn more!
Automatic test app
Testing your apps just got a whole lot easier!
With the new automatic test app, you no longer need to set up a project and manually add your app before testing it. Instead, when publishing, a dedicated test app is created for you instantly. From here, you can invite colleagues or clients directly to test the app and gather feedback in a safe way before deploying it to production.
You can find the test workspace on the app details page of your app.
Note: Don't see the test app yet? No worries! This feature is still being rolled out in some environments and will be available soon.
Dashboard entities without lock
You can now use dashboards as shared landing pages that everyone can open at the same time!
By default, an entity is locked when someone else is using it. You can now disable saving on top-level entities, which removes the locking mechanism and allows multiple users to access dashboards simultaneously.
Visit the community to learn more about this feature!
App Builder updates
Another round of improvements on the App Builder!
  • Expanded Python package support: more libraries to work with out-of-the-box Improved code generation: cleaner output, fewer duplicates, and better defaults for tables and arrays
  • Performance tweaks: quick views are now preferred unless heavy compute is needed, improving responsiveness
  • Smaller concluding remarks: less noise after code generation, now streamed instead of instant
  • Smarter responses: the App Builder now asks clarifying questions when uncertain
Check out the documentation to learn more about what you can do with the App Builder.
Faster app publishing
We’ve improved the packaging step of the publishing process by switching from pip to uv, which is significantly faster. The result? Shorter waiting times, faster iteration cycles, and more time spent building instead of waiting. Find out more here.
Community Spotlight
This month in the Community Spotlight, we feature Shaun Infantino's application: Peak Velocity Pressure for Falsework.
The app helps engineers quickly calculate peak velocity pressure for temporary works structures using the simplified method from BS 5975. Instead of manually working through the standard, you can simply select a location on the map, adjust a few inputs, and let the app do the heavy lifting. The result? Faster, more consistent calculations that save time and reduce repetitive work — so engineers can focus on solving bigger design challenges.
Ready to give it a try? Check out the app here.
  • SDK version v14.24.0 is now available: changelog
  • CLI version v0.44.3 is now available: changelog
  • Prevent closing dialogs via backdrop click in several places in the user interface
  • Fixed error when triggering a method with name or label that exceeds a certain length
  • Fixed app deployments in development not being synced when updating app variables
  • Fixed error when cancelling first prompt in the app builder
  • Fixed error when trying to use addons in the app builder
  • Fixed error when uploading a file in the app builder
  • Improved administrator users page performance
  • Improved copy of several error messages in the app builder
  • Removed the beta AI assistant for view generation in favor of the app builder
  • Fixed the input not being visible when entering values into a table field in the app builder
  • Optimized parametrization validation when reloading app in developmentFail early when parametrization button refers to a view-decorated method
Build this app now
