August 21, 2026
This month brings smarter views, easier ETABS and SAP2000 integrations, more table customization, and several improvements across the VIKTOR platform. Keep reading for what’s new!
New ways to customize tables
We've added more ways to customize tables in your apps! You can now use formatted text such as bold, italic, and links within cells. Learn more about styling and formatting text in tables using markdown here.
Views now only update when needed
The views in your app now only recompute when an input they actually use changes.
Previously, changing any input could mark all views as out of date, including unrelated ones. For example, changing a project name will no longer recompute a beam visualization if that view only uses the beam dimensions.
Each view also now has an update button and timestamp, so you can see when it was last calculated and refresh it manually when needed.
Integrating with ETABS and SAP2000 is now easier
Connecting ETABS or SAP2000 to a VIKTOR app no longer requires a separate Python script. This script was sent from the app to a local worker on your computer, where it was executed to interact with the software.
The new generation of ETABS and SAP2000 workers changes this. You can now write your integration as if you were communicating directly with the ETABS or SAP2000 API. Instead of executing Python code locally, the connection is limited to actions within ETABS or SAP2000.
The new ETABS and SAP2000 integrations are available in the App Builder for everyone to use. The App Builder is optimized to work with both integrations.
Visit the documentation to learn more about setting up ETABS and SAP2000 in VIKTOR.
Admins
Manage all apps in one place
The new All Apps page gives administrators a single place to manage every application in their company environment. View apps in a list or grid, quickly filter and sort them, and perform bulk actions.
Tried the new All Apps page? Let us know in the Community what works and what we can improve.
The App Store has been renamed to Library. Visit the Library to explore all the apps available within your organization.
  • SDK version v14.33.0 is now available: changelog
  • CLI version v0.49.0 is now available: changelog
  • The App Builder preview environment now uses your app's configured memory limit for more accurate testing
  • A progress bar now appears in the editor input panel while a job is running, so you can easily track its status
  • Chat conversations are now preserved across code revisions in the App Builder instead of showing an error
  • The children button has been moved from the "more actions" menu into the main header area for quicker access
  • Unverified apps are no longer hidden in strict verification environments
  • The Library sidebar is now visible to all non-external users
  • The "Add to Project" action is now disabled or hidden for apps that aren't verified or published
  • Geometries are no longer automatically centred to the scene origin in GeometryView
  • Tab scroll buttons on the admin activity page are now hidden when they aren't needed
  • The local development page in user settings has been refreshed
  • Worker icons have been updated to make Python dependencies easier to identify at a glance
  • The autosave manual save button has been made clearer
  • Fixed breadcrumbs in simple and tree type apps (including test apps) incorrectly linking to the app details page
  • Fixed duplicate file names blocking uploads in the App Builder
  • Fixed an issue where expired or invalid login details could cause a stuck loading state
  • Fixed alphabetical sorting on the Develop page and App Store
  • Removed outdated banners from the Home and Develop pages
  • Various performance improvements and minor bug fixes across the App Builder
Webinar recap: Agentic engineering is here, introducing the VIKTOR Agent
What's new in VIKTOR (November 2026)
How to automate quantity takeoff and QA/QC in Plant 3D with VIKTOR AI
