This is one of the reasons why we created the AutoCAD integration in VIKTOR AI. You can now easily turn these tasks into parametric apps. You describe the drawing, configure the inputs, and generate the geometry in the AutoCAD drawing you already have open. In this blog, we created three starting points for you: a simple 3D structural frame, a steel truss bridge, and a reinforced concrete beam detail. VIKTOR AI's AutoCAD integration generates all three directly inside your open AutoCAD drawing, from a single prompt.
The VIKTOR platform gives you one place to build engineering apps, connect them to your software, and share them with your team. The App Builder creates an app from your drawing requirements, while the AutoCAD integration connects it to your local drawing. You can test the app with familiar geometry, refine the inputs and drafting conventions, and reuse the same workflow on another project.
Once an app works the way you want, VIKTOR does more than run it. You can test and publish it through an extensive DTAP (Develop, Test, Accept, Production) pipeline and move it from development to production with the checks in between. Then share it through the Engineering Library so a colleague can run the same reinforcement detail or frame generator without rebuilding it. Every input, drawing, and result also feeds the Company Knowledge base, so the detailing conventions you set up here become something the next engineer builds on instead of starting from a blank drawing again.
In this blog, you will automate the following AutoCAD workflows:
A 3D structural frame: create a quick starting model by adjusting the number of bays, member sizes, and slab dimensions.
A 2D steel truss bridge: reduce repeated drafting by generating coordinated views, dimensions, and member marks from configurable geometry.
A reinforced concrete beam detail: reuse a common detailing pattern across projects by changing dimensions, reinforcement, and clear cover.
A single prompt in VIKTOR AI generates a parametric 3D structural frame directly in your open AutoCAD drawing, with bays, spans, and member sizes you can adjust and regenerate.
For a simple structure, a quick 3D model helps you inspect the proportions, bay arrangement, and relationship between columns, beams, and slabs before developing the design further.
The first prompt creates a structural frame from configurable dimensions. You can change the number of bays, span, storey height, and member sizes, then inspect the resulting solids in AutoCAD. Separate layers and colors make the different element types easier to review.
Before running the app, install VIKTOR Desktop, sign in, add AutoCAD, and start the personal worker. Open the intended drawing in your licensed AutoCAD installation on the same Windows computer. The AutoCAD integration guide explains this setup.
Let's see this in action. Use the prompt below in the App Builder to create the 3D structural frame app.
Start with one or two bays and inspect the model from several directions. Check the member dimensions, slab position, and intersections before generating a larger frame.
You could adapt this workflow for a small timber shelter or shade structure by asking the App Builder to replace the slab with roof members and add roof slope and overhang inputs. That gives you a quick geometry model for exploring the arrangement, followed by more detailed work on connections and structural design.
This VIKTOR AI prompt generates a parametric 2D steel truss bridge, plan, elevation, cross-section, dimensions, and member marks, directly in your AutoCAD drawing.
After creating a 3D frame, you can apply the same parametric approach to coordinated 2D drawings. A truss is a good example of a structure where a few geometry decisions create many repeated drawing elements. Changing the span or panel arrangement affects the chords, diagonals, member positions, and dimensions. Repeating those changes manually across the plan and elevation takes time.
This second prompt turns that drawing logic into a parametric app. You configure the bridge geometry and member sections, and the app draws the views and annotations in AutoCAD. The result gives you a solid starting point for a more detailed model, where you can develop connections and project-specific details.
You can develop the same app further by changing the truss topology. Try this follow-up prompt:
Change the truss topology to an arch truss with a curved upper chord and a straight lower chord. Add inputs for the arch rise and number of panels, and retain the configurable span, bridge width, and member sections. Update the plan, elevation, cross-section, dimensions, and member marks to match the new geometry. Preserve drawing content unrelated to this app.
This VIKTOR AI prompt generates a reinforced-concrete beam detail, elevation and labelled cross-section, directly in your AutoCAD drawing, ready to reuse with new dimensions and reinforcement values.
The bridge example automates repetition within one structure. Reinforcement detailing applies the same idea across projects. A beam between two columns may follow a familiar drawing pattern, but the span, concrete dimensions, bar diameters, and stirrup spacing change each time.
With this prompt, you can create a parametric detail that generates both the elevation and a labeled cross-section. Changing the inputs gives you a new version of the detail without manually moving every bar and rewriting every annotation. This provides a starting point for a library of custom reinforcement details your team can reuse.
Open the reinforced concrete beam example in the App Builder
Turn the detail into a reusable block with this follow-up prompt:
Group the beam elevation, cross-section, and annotations into a named AutoCAD block. Let me set the block name and insertion point, and generate a new version from the app's dimensions and reinforcement inputs without overwriting existing block definitions.
VIKTOR is expanding the AutoCAD integration to support DWG downloads, multiple open drawings, and more drawing operations.
The product team is moving quickly to expand the AutoCAD integration. Current limitations point to the following areas for future development:
DWG downloads: return generated drawings directly to VIKTOR for download and project records. Currently, you save the result yourself in AutoCAD.
Multiple drawings: extend the attach workflow to work across multiple drawing files. Currently, these apps work in the active drawing of the attached AutoCAD instance.
More drawing operations: expand the supported automation workflows. Currently, the integration uses the AutoCAD ActiveX API and blocks command execution, macros, and operations that wait for user input in AutoCAD.
Share the drawing tasks you want to automate on the VIKTOR Community to help us prioritize what comes next.
VIKTOR AI turns three recurring AutoCAD drafting tasks, a structural frame, a truss bridge, and a reinforcement detail, into apps you can configure and reuse on every project.
These three prompts turn repeated drafting tasks into configurable workflows. You can create a simple 3D frame as the starting point for further design, generate a truss drawing, or reuse a reinforcement detail with new parameters. The value comes from keeping the drawing logic in an app you can refine and use again.
VIKTOR brings the inputs and AutoCAD connection together, so your team can test the workflow, agree on its drafting conventions, and reuse it across projects. Try one of the prompts above, or book a demo here to explore your team's AutoCAD workflows.
October 27, 2026
October 09, 2026
